maybe I missunderstood, does it still have the sugested word for miss spelled words. in the pro version
word sugestion
yes, that's (still) in the pro version
the point of my post is that I dont see it, on the stock android keyboard it is right above the keyboard when you type, I dont see this on the pro version
And it should be there... are you sure you are really using the Pro version ? (choose "Smart Keyboard Pro" in the "Input method" dialog which appears after a long press in an input box). You can check with a long press on ?123 key to enter the settings, then you should see "Smart Keyboard Pro" in the "About" dialog. You should also have suggestions option enabled, but it's enabled by default (in the Pro version)
sure enough operator error, thanks for you help
