Thai numeric key for 2 (๒) is missing in v3.14.0
admin@nkkthai.co.th
Thai numeric keyboard for 2 (๒) is missing in v3.14.0 (25/02/2011)
Thanks for reporting, this will be fixed in the next version
Can you try the latest beta?
BTW I wonder why it's the first feedback I get about Thai layout, while it has been in the keyboard for 8 months!
admin@nkkthai.co.th
I think the layout is wrong since implementation of THAI keyboard.
As I am back to v.3.13.0 due to crash of v.3.14.0 to my AD 2.1
The missing is the same, namely Thai numeric key for 1 (๑) is shown in both lower & upper key layout.
Therefore, just simply replace either 1 (๑) with 2 (๒) in your future keyboard layout.
Frankly, I am getting bored of installing new software to my Xperia X10 mini, & crash it instantly.
Yes the layout was wrong, but I fixed it in the 3.15.0 beta, which you can download from the link above.
I'm sorry for you, but only two people out of 50000 users reported this problem, and once again I will be happy to fix it IF you send me your phone logs at the time of the crash, which is the only way for me to understand/fix the problem. Note that if the whole device crashes, you need to get logs with the command "adb logcat", thanks to the ADB tool present in the Android SDK.
admin@nkkthai.co.th
[quote="cyril"]Yes the layout was wrong, but I fixed it in the 3.15.0 beta, which you can download from the link above.
I found no link to the captioned bata.
Thanks anyway, for your fixing !
Do appreciate your prompt action.
