altough I like the product very much I found a minor issue:
The "period on double space" feature is active for password fields. This way passwords containing a double space cannot be entered correctly (as smart keyboard inserts a period) and the user does not see any hint that explains the failed password entry attempt. Easy fix: 'period on double space' and any similar feature that automatically changes the text should not be active for password fields.
Otherwise, this is really a great product; easily worth the price. Thank you!
C.
C.
