:( how do I type words that are not suggested?
thao
I'm stuck :( was using T9 keypad. I wanted to type "woa", which is not in the dictionary. It's also not suggested in the suggestion bar, and there I was stuck. I couldn't figure out a way to manually type in that word.
I was so sad.I thought I found THE perfect keyboard. But seems like the search hasn't ended
Well, nothing special, you do like on all your old phones... disable T9 prediction (the T9 button), and press "mno" 3 times to get a "o"
