Add word to dictionary request?
Brooke795
Hi! is it possible in an update that we can touch twice to add that word to our "dictionary?" that seems to be the only thing missing from this fantastic keyboard!
Thanks for such an already great product!
You can add words with a long press, is it really more difficult than double tap?
yup - that is working well for me - plus good use of the custom auto text :)
btw: just checked settings and i didnt have smart dictionary on - just turned it on so might all go wrong soon :D
....now it would be cool if for custom auto text from gesture, it could pull in the word that you want to map ;)
ie: ive typed in 'fir' and want to map it to 'for', so use the gesture to go to auto text. would be good if it could fill in the first field with the entered word
so i just have to fill in the 2nd field ?
