i just installed smart keyboard trial to my new galaxy sii. during registering, my big finger touched "korean" locale instead of "thai" as i intended. from then on, the world turns upside down for me. the app's shortcut button disappears. my other keyboards disappear. all the menus and names and all texts then turn into korean. my uninstallers and task managers cannot find it nor uninstall it. i don't know how to go back to the beginning again. now i cannot communicate with the phone. it is totally alien to me. anybody knows how to get out from this stage and go back to the beginning? please.
need help, i chose wrong locale. cannot communicate.
you just need to change back your locale; press the "menu" key of your phone to enter the settings (you should recognize the settings icon, it looks like a volume button), go to "Language & keyboard" (as it will be written in Korean, you can guess which menu item it is thanks to the "A..." icon on the corresponding line), then "Select language" (it's the first item of the "Language & keyboard" menu), then choose your language.
thanks a lot cyril.
