Del key - delay needed.
jetrost
Would it be possible to add a delay to the Del key so that it doesn't start deleting until you've held it down for a certain amount of time, or after you have release it?
I have problems when I go to type a "?" by holding down the M, but while I am moving my finger around to get it on the M-button, even if it passes over the Del-key, one/a few letters are deleted from the end of my text.
it's not possible to do it after a release, otherwise the "repeat" mode will not work. Anyway I may be able to add a delay, I'll check that
