Word left over after sending message
repo97
I have noticed that almost every time I send a message there is usually the last word left over after pressing send. For example: I send a message "Hey how are you" and press send. Then when I close the chat down, then open it back up again from the inbox the word "you" is in the chat window as if I typed it. I end up having to delete the word to type in another message, and pressing back saves the message as a draft. Anyone else see this on their phone?
cubanjinx
Its cuz u never actually accepted the word by hitting space (or selecting it) so it remembers it as the last word u typed
Via TT
serenewaffles
Try using enter to select the word instead of hitting the send button if that is an option. It solved this problem for me as enter accepts the word (clearing the suggestion) and then sends the message.
