Why is the priority word from the selection (above the keypad) in the middle of a sentence sometimes randomly capitalized? Just general words, not names, places or dates etc.?
auto capitalize
Can you give a precise example of what you type, and what you see in the prediction bar?
"Have a Good day, I'm off to Work"
The prediction bar does have the lower-case version however this comes up first.
It could well be that I've somehow done something to my settings to make these words auto-capitalize, however I'm not sure what it is or how to rectify it.
I guess these are in your contacts and you enabled the contacts dictionary, or you added them in your user dictionary.
To clarify from my experience, if when the first time you add a word to the dictionary it is written with a capital, it will be remembered with the capital. If you first type it lower case it can then be typed either caps or lower. Just go into your user dictionary to find these 'random' capitalised words and remove them.
That's it thanks! The words are in my contacts list, I shall edit them there.
