I had the trial, liked it a lot, and bought a license for the Pro version. However, it appears I must re-enter all the custom autotext entries I made in the trial version. Is there anyway to use the entries I input in the trial version in the Pro version? Also, will deleting the trial version affect the Pro version?
Can I use Auto Text entries entered in trial version in Pro?
There are 2 ways:
1) backup your settings from the trial version, and use "restore from trial" option in the pro version
2) export your autotext entries from the trial version, and import then in the pro version
Afterwards, deleting the Trial will have no effect on the Pro version
Many thanks.
