No landscape suggestions
Dimmie
Disabling suggestions in the Landscape mode also disables auto-correct!
1) Check the "No landscape suggestions" in the Settings-Text Prediction
2) Type "helo" using Smart Keyboard in landscape mode
3) Notice that the auto-correct didn't work, didn't correct it to "help'
Expected: Checking the "No landscape suggestions" should not disable the auto-correct or it should be renamed to "Disable auto-correct in landscape".
