IPhone Skin
meraj1509
Hi, I had downloaded the trial for Smart Keyboard and liked it very much, so when the trail ended and the app started asking me to buy it I did. However after I paid for it, I had to uninstall the trial and install the Pro. Since I have done that I’m having a problem with the keyboard Skin. Under General settings | Select Skin….. I have the IPhone skin chosen…however when I try to text or use the keyboard the skin that the app uses is the Android skin. I have tried to changing the skin back and forth along with uninstalling other keyboards that I have installed but nothing helps. I want to use the Iphone skin but it’s not working. Is there anything you can do to help?
