Hello,
I seem to have a bizarre issue with your keyboard. Originally, I only had the trial version and thought it was disabled after some use in order to prompt me to buy the full version. Unfortunately, after buying the pro version I have found that its just as broken. I use T9 in portrait mode only, and after what seems to be a random amount of time, the predictive text capability stops working. Regardless of what settings I use, I cannot make it work again, and the only remedy I have found is to uninstall it and reinstall it from the marketplace. It seems to happen when switching to and from T9 from the compact keyboard, which I occasionally use to type things not in the dictionary.
I originally moved to your keyboard from Better Keyboards' atrocious T9 variant. Your T9 is the closest thing I can find to the perfect T9 keyboard I had on my LG Dare, but unfortunately, I am deliberating uninstalling this keyboard forever as it becomes tiring reinstalling it three times a week.
Have I found a bug? Let me know if you need any additional information as I would greatly appreciate this to be fixed.
Thank you.
Thank you.
