Thai keyboard layout - Trial 4.0.2
MissingOne
I'm not sure if you would call this a bug report or a feature request.
Currently there is no key for Thai Baht (Thai currency) symbol ฿ (0E3F in Character Map).
Normally, the key is the shift of ึ (top row 7 from left in SKP layout).
The current layout put the symbol ๎๎ (0E4E) which is hardly used and not on the typical keyboard.
I'm wondering if you'd consider changing it.
PS. for your reference, a typical Thai keyboard layout.
http://www.hawaii.edu/thai/thaifonts/th ... ardmap.gif
Thanks,
Yes this is a feature request ;)
Well, I trust you if you say this has to be changed. I did it in the latest beta
MissingOne
Thank you very much for trusting me and for changing it. :D
