Autotext and % (percent sign) problem
kiwibird
First of all: great job with Smart Keyboard, and the very useful autotext feature. I use it to replace my great Keytext software on Windows. Developer(s): be assured you have a good bunch of enthusiasts supporting you.
Autotext seems to have a problem with the % (percent) sign. The text
discount 20% for
becomes
discount 20for
once pasted with autotext into any app.
Hopefully this can be fixed soon?
Or is there a workaround?
NickC
Hmm.. I'm not having his issue. Typed in exactly what you said and it's working fine. Can you check your custom auto text and see if that has accidentally been added?
% is an escape character; if you want to display %, you need to put %% (this is in the user's guide ;) )
