Manually saved words
maxzat
Hi all!
Don't know the English word for it, but how many words can you save to the dictionary? I'm not sure but it feels like some words are missing that i think i know i saved some time ago. I try to frequently backup but it's quite possible i've missed here. I change ROMS from time to time, therefore my need for backup.
If it's to any use i'm using Swedish.
Technically there may be a limit but I guess it's much higher than what you could ever add to the dictionary. There will be performance issues if you add thousands of words to the dictionary, but nothing should prevent you from doing so.
