Can not restore saved setings - Keyboard hang
polzovotel
On Samsung SGS i9000 with Darky rom - If I backup the keyboard settings and then try to restore them I get total keyboard app. hang.
Is there any workaround for this ?
I am using the latest version from Market (PRO version).
Can you get the phone logs while this happens? Do you use app2sd?
polzovotel
cyril wrote:Can you get the phone logs while this happens? Do you use app2sd?
I do not use app2sd.
As for phone logs - did you mean enable "Enable debug Logs" option in Smart Keyboard advanced setting ?
No, I mean install "Log Collector" (or any similar tool) and collect the logs just after you get this problem (no need to enable debug logs)
polzovotel
cyril wrote:No, I mean install "Log Collector" (or any similar tool) and collect the logs just after you get this problem (no need to enable debug logs)
Ready - sent you PM
polzovotel
did you get the logs ?
Thanks.
kamzik
Same problem here.
I just bought Smart Keyboard PRO and wanted to import settings from TRIAL version.
Created backup.zip is corrupted and application hangs when trying to import backup. Also backup.zip from newly installed PRO version is corrupted and cannot be open also in computer. See attachment.
backup-pro.zip 482 B · downloaded 332 times
polzovotel
for some reason it seems that Cyril ignoring this issue ...
The reason is that it's not a critical problem and I'm very busy. I will look at this one
polzovotel
I fully agree that it is not critical.
But droping a message here saying that would be appriciated.
polzovotel wrote:Hi,
Thanks.
I don't see anything wrong in the logs. Can you also send me the backup.zip ?
polzovotel
Sent you by mail. Let me know if you need anything else.
The zip file is indeed corrupted.
