Skins! Request!<3 C:
Please read this: http://www.dexilog.com/smartkeyboard/skins
I would love for someone to make these keyboards too!!
looks easy, I'll try it.
EDIT : first try below
I'll probably release a better one later today, and the second one probably in the evening.
Feedbacks are welcome ^^
Cloudy Glass.zip 32.7 KB · downloaded 3,041 times
External image (dl-web.dropbox.com)I'll probably release a better one later today, and the second one probably in the evening.
second one, using only a background instead of keys backgrounds
(avoiding holes between keys, but limited to 4 rows)
Cloudy Glass 4rows.zip 50.2 KB · downloaded 2,503 times
External image (dl-web.dropbox.com)Not exactly the second and third screenshots, but really close to.
newbk5.zip 22.1 KB · downloaded 2,501 times
External image (dl-web.dropbox.com)Thank you. c:
the second is realy nice but on mine phone is give it this.. D:
External image (lh6.googleusercontent.com)
I'm on it.
super!!!! it works!!
External image (lh5.googleusercontent.com)
quesstion do you can check mine skin it not showing up whit the skins on mine phone ..
yakie996 wrote:super!!!! it works!!i found it. it was a .rar but it shows black (like the normal skin 'black') and not the colors dat i had...
edit do someone can make this?? https://market.android.com/details?id=m ... rch_result
easy, your files have twice their extension.
for example, your XML requires a normal.9.png file, but in your drawable folder, all you have is a normal.9.png.png one
2 ways to solve the problem :
- Go in your folders settings, under control panel, and UNcheck "hide known extensions"
- or, just remove the extension you added once more
but I personally prefer the 1st bullet
yakie996 wrote:edit do someone can make this?? https://market.android.com/details?id=m ... rch_resultDon't you have a market access on your phone ? this skin seems to be downloadable for free
meyergre wrote:i it compatibel with smart keyboard??yakie996 wrote:edit do someone can make this?? https://market.android.com/details?id=m ... rch_resultDon't you have a market access on your phone ? this skin seems to be downloadable for free
To apply, open Better Keyboard/Smart Keyboard settings console, choose Skin/Theme.According to the author, it is.
yakie996 wrote:i it compatibel with smart keyboard??Yes. Any Better Keyboard skin is compatible, unless it's by the developers of Better Keyboard.
meyergre wrote:easy, your files have twice their extension.I did the 1st bullet but is still not working..
then just remove the 2nd extension on each of your files, once you unchecked the box, you should be able to see them. all your files finishes with ".png.png" instead of ".png".
After that, if it's still black,then the problem should be somewhere else...
meyergre wrote:then just remove the 2nd extension on each of your files, once you unchecked the box, you should be able to see them. all your files finishes with ".png.png" instead of ".png".always black --'
post your file
plss
you forgot the following files :
meyergre wrote:you forgot the following files :just compare these filenames with the ones in your skin.xml, you will find all the mistakes
witch mistakes i don't find..
the double extension, of course !
you only fixed the .9.png files, you should do the same for the other files.
in your skin.xml, you indicate to use backspace.png, but this file is actually named backspace.png.png in your drawable folder.
So, the names doesn't match, it can't work!
EDIT : here is your skin, which should work now.
yarni-ok.zip 15.2 KB · downloaded 1,067 times
meyergre wrote:the double extension, of course !notting works..
Only the button backgrounds are .9.png, other ones are classic .png !
If you naame them .9.png, the skin engine will search for the black lines, specific from the .9.png file format. Use this format only for stretchable pictures !
To sum up :
Name your symbols only ".png", and do the same in the skin.xml.
Don't touch the buttons anymore, if should work.
Sent from my Adam using Tapatalk
To sum up :
