Hi.
I'm just a beginner, so maybe this is a not-issue ...
I installed the trial version of SmartK. last week, on my Sony Ericcson X10 Mini Pro (Android 2.1, with a hardware sliding QWERTY keyboard).
The idea is to use SmartKeyboard only in portrait mode (when the hw keyboard is closed), and viceversa NOT to use it in landscape mode, but to use the hw keyboard (and I don't want suggestion, dictionary, completion etc in this case: i want my hw keyboard).
Also, I'm using a modified layout of my hw keyboard (I added, ALT+several keys to obtain extra chars, like [] {} etc)
BEFORE your last update, everything worked ok
AFTER your update, I have a problem:
In landscape mode, when using the HW keyboard, NOW THERE IS A SMALL ICON at the top-right bar, showing "IT" (that is probably the ITALIAN layout, I use the T9 italian dictionary). This icon disappears in portrait mode.
The problem is that now your program seems to DISABLE my own hw kbd layout, and sets a very standard one (without all my parenteses!)
So the question is:
I DON'T WANT SMART-KEYBOARD TO INTERFERE WHEN IN LANDSCAPE MODE, I just want to use the hw keyboard with my own settings!
How can I do it ? I think that managing to disable that icon (the "italian layout set" feature) it should work again (?!)
I don't want any layout in landscape (but neither in portrait!) : I just want that, when in portrait mode and using the "T9 compact keyboard", the dictionary must be in Italian (like in my 1995 Nokia phone!)
So, maybe if I just set (where??) "use english/default layout"
or "never change keyboard layout"
or "just use italian dictionary in T9, do not set italian layout in hw keyboard"
it would work ...???
Thanks, regards
Enrico
So the question is:
Thanks, regards
Enrico
