selection box for voice dictation
jwn167
i just had to switch from one droid x to another. after the switch i can't seem to activate the dialog box that gives me several choices to choose from upon voice dictation. i believe i am using the proper activation key in the settings but it is not responding. i unloaded and reloaded the app. it worked fine on the old phone? can't understand why it isn't and how to fix it.
You have to disable "voice input best choice" option. Is it what you did?
