Compact Keyboard
delriogil
Thank you so much for the compact keyboard. I love it and it keeps getting better with time.
Well here's a bug I caught. When using the autotext option on the keyboard and having the keyboard set to compact keyboard, it's not inputing letters I ask for. For example, if I want to set autotext to leta -> let's, it's not letting me input s. Instead it's showing the letter a, even when I push the soft key twice for s.
Is it with "XT9" enabled ? In that case it's normal, and if you disable it, you should be able to type what you want with multitap
delriogil
cyril wrote:Is it with "XT9" enabled ? In that case it's normal, and if you disable it, you should be able to type what you want with multitap
XT9 isn't enabled and the multitap isn't allowing me to choose the letter s when I want to use the Custom AutoText. When the XT9 isn't enabled using the keyboard normally, multitap works just fine. It's only on Custom AutoText when mutitap won't work.
Ah ok I see... will try to fix this
