When using "text suggestions" does the Smart Keyboard prioritise the words/letters that you use often?
For example, the names in the contacts seems to be at the top of the list of text suggestions but would this change over time?
Or if you want to write "x" at the end, "y" always comes up first but the more you use "x" prioritise it?
If so, is there perhaps a setting for it?
Thanks in advance!
Thanks in advance!
