I'm using the SmartKeyboard Pro app, and find it very nice. However, a small problem appears if I want to backup my settings with the built-in option in "Save > Save on SD card", the message "Backup Failed!" is always shown.
I used logcat to see a bit what's happened and here is the traces I got:
It seems to be a bug with the last version: the app isn't looking at the right place for this file, because I'm pretty sure I was able to do a save on SD card before.
By the way, my settings seem to be saved properly anyway.
Hope you can fix it fast (or give me any clue on it).
Thanks in advance.
06-22 11:58:45.340 I/SmartKeyboard(20426): Backup file /data/data/net.cdeguet.smartkeyboardpro/databases/autotext.db
06-22 11:58:45.344 I/SmartKeyboard(20426): Backup file /data/data/net.cdeguet.smartkeyboardpro/databases/userdic.db
06-22 11:58:45.346 I/SmartKeyboard(20426): Backup file /data/data/net.cdeguet.smartkeyboardpro/shared_prefs/net.cdeguet.smartkeyboardpro_preferences.xml
[b]06-22 11:58:45.346 W/System.err(20426): java.io.FileNotFoundException: /data/data/net.cdeguet.smartkeyboardpro/shared_prefs/net.cdeguet.smartkeyboardpro_preferences.xml (No such file or directory)[/b] Indeed the file "net.cdeguet.smartkeyboardpro_preferences.xml" is not there. It is stored somewhere else, in: /dbdata/databases/net.cdeguet.smartkeyboardpro/shared_prefs/net.cdeguet.smartkeyboardpro_preferences.xmlIt seems to be a bug with the last version: the app isn't looking at the right place for this file, because I'm pretty sure I was able to do a save on SD card before.
Thanks in advance.
