2 suggetions.
star2205
1.
Hangul has three parts, It is initial consonant, neutral vowel, and final consonant.
for example, on 한, ㅎis initial consonant, ㅏis neutral vowel, and ㄴis final consonant.
When deleting words, if the sentences is underlined(or activated), deleting input operates not letters, but more small unit, which is initial consonant, neutral vowel, and final consonant.
for example, when deliting 한국의 수도는 서울, the input result is not 한국의 수도는 서, 한국의 수도는 but 한국의 수도는 서우, 한국의 수도는 서ㅇ 한국의 수도는 서,
한국의 수도는 ㅅ, 한국의 수도는
(But, the sentences isn't underlined, results is 한국의 수도는 서울->한국의 수도는 서.)
it is so inconvenient and makes typing slowly, because many deleting inputs are needed in small unit, therefore I want that when deleting words, one delete correspond to one letter except for last letters in underlined words.
(for example, 한국의 수도는 서울-> 한국의 수도는 서우, 한국의 수도는 서ㅇ, 한국의 수도는 서, and 한국의 수도는. )
What I saying is perfectly matching that of google korean IME.
Because of my lacking fluency in english, I worry about your understanding.
one more time explaing this,
in 한국의 수도는 서울
한국의 수도는 서울 ->(del)한국의 수도는 서우->(del) 한국의 수도는 서ㅇ->(del)한국의 수도는 서->(del) 한국의 수도는.
Do you understand difference between 울 and 서?
울 is lasts letters in underline, and 서 is not, so 서 is deleted one input.
If you accept my suggetions, It is well that this feature is supported by option in setting.
2. I want to set up key height differently in T9 mode and qwerty.
Not sure how easy it is to implement this, but I understood
