Problem with moving cursor to the right side of the text
Gabs
Hello,
I guess I found a small bug in Smart Keyboard Pro. Moving the cursor to the right, either by using the arrow keys or by a pre-defined gesture, does not work. All other directions - left, up and down - work perfectly. Strangely, it does not happen always, but very often. Can you please try to verify and fix this? System is Samsung Galaxy S2 with Android 2.3.3 (no custom ROM etc.).
Thanks,
best regards,
Gabs
