Swap (or allow swapping of) "<>" and "ABC" keys
dland
The <> key, which brings up the pad with the numeric keypad, Esc, Tab, and cursor keys, is "in the way" — I want to quickly swap back and forth between 123 pad and the ABC pad, but the <> key is in the same place as the 123 key.
For the vanishingly few times I use the pad behind the <> key, I can move my thumb to the right to reach that pad.
PhilD
dland wrote:The <> key, which brings up the pad with the numeric keypad, Esc, Tab, and cursor keys, is "in the way" — I want to quickly swap back and forth between 123 pad and the ABC pad, but the <> key is in the same place as the 123 key.
have you tried setting the swipe feature in options? I think a gesture for toggling between the numbers and letters (swiping to the right across the keyboard) is set by default. I added a swipe to the left gesture for togling the cursor keypad, works great
cadillac
No it is not possible. I need the same.
