Hey there
First of all .. great keyboard, really worth the money for the Pro
I have one small feature change request though. For the QuickFixes settings.
Currently this etting needs to be turned on to use the integrated QuickFix settings, as well as the user-defined ones and the Suggestions/Dictionary settings.
My problem is the QuickFix that the application does that I have no or little control over.
F.x. if I type 'i', which should not be capitalized in danish, it is automatically capitalized to 'I' every time.
Also when using applications that don't allow for the smileys button, when I enter a text and then try to make a smiley, the colon is always moved right next to the last letter.
Example: 'Have a great day
' becomes 'Have a great day: )', unless I move the colon manually. It is rather annoying.
Problem is that if I turn off QuickFixes setting, then my dictionary and Suggestions don't work either.
So my suggestions are these:
1. Make a List in the settings with the QuickFixes that are intergrated in the keyboard, so I can either edit it, or disable it if needed.
2. Enable me to select whether I want it to QuickFix colons, semicolons, commas and punctuation characters, so they are automatically moved next to the last letter in the string.
Thanks in advance.
Thanks in advance.
