dioes it work with the Motorola Android Pro?
fihner
I got the trial app from the Android App Market and installed and made the necessary settings...All appears fine, but on long hold, I select INPUT METHOD and select the Smart Keyboard nothing happens. Is this possibly because the Android Pro phone has an external keyboard and will not allow this app to work ??? Need some advice, please.
Yes that's because of a Motorola bug with the hard keyboard. You need to enable the advanced option "ignore hard keyboard" in smart keyboard settings.
