I have the trial version and everything SAYS that it has everything the Pro does except the pop up. Not so! I do NOT have ANY Skins options! Is this ONLY on the Pro version? If not, why is it not showing in my settings?!
skins
Yes, the Trial version IS the same as the Pro version except the popup.
Where are you looking at the settings? Have you correctly enabled the keyboard as explained in the user's guide?
