Swiftkey x skin
Hi, can be made skin like new SwiftKey X have? I mean the dark and green.. I will post the image later.
I have to say, nice work here...I'd say it's better than the real SwiftKeyX.
YOURE THE MAN...its awesome and really thnx for it...even my girlfriend using it and saying that its the best skin she ever have. Thx again
Meyerge can you fix the suggestion bar? im back to SK and using your skin but suggestion bar have one more row which is empty. can you fix it? Thnx
Gnaver wrote:Meyerge can you fix the suggestion bar? im back to SK and using your skin but suggestion bar have one more row which is empty. can you fix it? Thnx
please attach a screenshot so I can see what's wrong
Sorry for delay meyerge but i was using another skins (i dont like them anymore) so i want to go back to this. And heres screenshot about the suggestionbar problem of mine. thnx for fixing it
swiftkeyx.zip 11.9 KB · downloaded 1,886 times
I reduced the picture half its original size, it should do the trick.
