User dictionary and Auto text
silvern18
Good evening,
I really appreciate Smart Keyboard PRO but I have to little problems:
Every time I try to write the word "mare", I get the word "mbre" as first result. I used this word once by mistake and I immediatly deleted it from the user dictionary but I still get that word.
Moreover, I used the AutoText feature to correct some words but it doesn't work correcting "fa" to "da".
Thanks a lot
Best regards
simon_s
I have a similar problem.
Whenever I type "hi" the suggestions bar suggests "his" instead of "hi". So when I email or text a friend and say type "Hi Joe" followed by the spacebar, it inserts "His Joe" which obviously makes no sense.
I cleared out everything in the user dictionary, but that didn't fix it. I even tried adding custom autotext that would replace "hi" with "hi" to force it to use "hi" when I typed "hi" but the suggestion still suggests "his" instead of "hi" and inserts that instead when I hit the space bar. Could this be a problem with the smart dictionary? The smart dictionary learns frequency of words I type to improve suggestions. I used to have the smart dictionary turned on... I have now turned off the smart dictionary but it still suggests "his" instead of "hi" so I don't know if it's something it remembers from before or if it's an unrelated problem. Although there's an option to clean the user dictionary, there there doesn't seem to be any way to clear the smart dictionary so that it forgets suggestions made based on frequency and just suggests what you type when it's a real word like "hi".
Any help would be appreciated.
- Simon
