New Hardware Keyboard Support
mystik1
I enabled the option in settings, but nothing seems to be coming up. Is there perhaps anything else I need to do? Thanks much in advance.
yes it's discussed in another topic, I'm working on a fix
mystik1
Great. Will look forward to seeing the update. Good luck!
mazz0310
This has been fixed and works very well now.
mystik1
The suggestions do indeed work now. Good job. It seems to break built-in capitalization, though. Also, something weird happens when you try to make an uppercas I when enabled. Check it out....
mazz0310
Yeah, something is also wrong, or atleast I've ran into it when you backspace to tr yto correct a mistake.
Richhead
Hi all.
Turning on Hardware Keyboard Support seems to make it no longer possible to enter numbers on the hardware keyboard ( either by pressing "alt" once or pressing it twice to lock it on ).
This was using Handcent on a Milestone on 2.01
Thanks.
Yes I know, ALT and SHIFT are more difficult to handle (especially when they are locked), I'll do it later ;)
delriogil
Someone mentioned earlier in the comments section in the Market for Smart Keyboard Pro that when misspelling a word and then backspacing, one has to completely erase the whole word in order for the suggestions to work correctly. I also have this problem using the hard keyboard but not on the soft keyboard. Using Motorola Droid.
