Option To Only Add Word To Dictionary If
phaze3131
My problem now is my dictionary is so cluddered with typos and words I do not want in my dictionary at all.
I propose an option to only add a word to the dictionary if it is chose from the list that appears above the keyboard as you type. I type in t9 and use the normal layout when I want to type a word that t9 cannot, but everytime I do that it automatically adds that word to my dictionary(which I do not want it to).
Like under "text prediction", where it says "learn new words" if there was an option below that to say "only learn new words when the selects it from the list"... or something to that effect.
This option would be great, like have it in settings to only add word to the dictionary if it is selected from the (east-west) scrolling list.
Thanks, love the app!
Travis
c00ller
You can disable "learn new words" and when you long press a word from the suggestion list it will add it to the user dictionary. This way you can control exactly which words are added to the dictionary.
phaze3131
that's what I ended up doing.ty for the help!:-)
