Android minimal version?
rhruiz
What is the minimal version to run smart keyboard? i have an Android 2.0.0 (api level 5) and no versions of smart keyboard are shkwing in the market for me.
2.0 is the minimal version. Where do you live ? Maybe you can try "Market Enabler" to see it, as others suggested
rhruiz
Hello Cyril,
I am from Brazil and I did try MarketEnabler with a couple of different operators but no luck. Not even the free version is showing up. I guess I will have to try again after the 2.0.1 update comes out :)
Evan
2.0.1 is out already. 2.1 is the one coming out soon. Or check out alldroid.org and you can get 2.1 now with a ton of cool stuff
rhruiz
Evan wrote:2.0.1 is out already. 2.1 is the one coming out soon. Or check out alldroid.org and you can get 2.1 now with a ton of cool stuff
Not yet for my South American Milestone, the methods availabe on alldroid.org will make me lose my 3G :(
