smart keyboard is not an option in keyboard type.
brjess
I purchased smart keyboard and I can see it , but its not a keyboard option. Thanks for the help
Did you follow the instructions?
How to install the keyboard?
Go to “Language & keyboard” settings (or “Locale & text” for Android <2.0) , and check the “Smart Keyboard” (or “Smart Keyboard Pro”) box. Then go into any app with a text input box, do a long press in this input box, and you should see a popup menu with “Input method”. Click on “Input method”, and select “Smart Keyboard (Pro)” in the list. Don’t worry if the “Open” button doesn’t work when installing the app, you don’t need this ! (a keyboard is a service, it’s not supposed to be “launched”)
