I have been using smart keyboard pro for a long time, and it has worked great. However, ever since switching to the bionic, I can't use it because it does not accurately capture my input. I think the glass on the Bionic is slicker than other devices I've had, and that is causing me a problem
When I enable showing the touch points and analyze what I've typed, it seems to indicate that my fingers do hit the correct key, but then drift far enough to activate an adjacent key when my finger leaves the digitizer.
Is there any way to force Smart Keyboard Pro to register the first touch event on key down and not key up?
Here is an example of what I experience:
http://i.imgur.com/QtDy1.png
