How to change Alt+key mapping on Motorola Pro+?
jaha
I am using the new Motorola Pro+ and have a problem/question about the Alt+key mapping on the hardware keyboard.
When I enable the "Physical keyboard" setting none of my alt+ keys are mapped correct. When I for example type alt+A i get a # but the button indicate an !. When pressing alt+A when setting "Physical keyboard" is disabled I get the correct letter !. When "Physical keyboard" is enabled the mappings are always wrong independent of which language I have selected in the "Language" setting.
Are there any methods to change the alt+key mapping on the hardware button in Smart Keyboard?
I am using the latest version of Smart Keyboard (downloaded yesterday) and the Motorola Pro+ just released in the UK.
Hope there is an answer to this question/problem, I really like the software but I also need my hardware key mappings to be correct.
Thanks in advance.
Best Regards,
Jarle
