Weird bug on Galaxy Nexus
fidaro
I've discovered another weird bug this time on Galaxy Nexus (Android 4.0.1).
Smart Keyboard Pro is the latest version.
Again this only happens with the Smart Keyboard not with the stock keyboard nor Google Korean IME.
The problem is if I type a Korean word and press enter or space Smart Keyboard inserts the character I have not typed.
This happens every time so it's impossible to type the correct word.
For example, if i type 넥서스 it becomes "넥섯스".
I had to type the above correct word with the standard keyboard because if I use Smart Keyboard,
it always changes the word into the wrong word.
I tried disabling all the auto correction features but this still happens.
Weird thing is this change only happens in the Internet Browser and doesn't happen in the GMail app or other memo app.
Any help would be appreciated.
Thanks,
nomota
same problem.
when I type korean letters ㄱ ㅐ ㄹ ㅓ ㄱ ㅅ ㅣ
tot type 갤럭시 then it automatically converts it
to 갤럯시. (doubled consonant)
same thing happens with ㅋ ㅣ ㅂ ㅗ ㄷ ㅡ
for 키보드 becomes 키볻드. (doubled consonant)
i'm using Trial 4.6.1.
this happens only on galaxy nexus.
on my other android, this doesn't appear.
thanks.
