can you maybe make the period and comma button a little bigger and the enter/happy face key a tad bit smaller or maybe even the space bar?? I can't ever hit those two buttons without hitting the wrong button beside them.
Bigger Period Button
not that easily, because many people want a bigger space bar... I will be able to make this optional in the future, but that's not easy at the moment
I'd like to second this proposal.
Using the compact qwerty keyboard, the comma and the dot are definatly the narrowest buttons, with the "?123" and the "return" keys wider than those most similar to them (the "'/0" and "XT9" or "L" and "Delete", respectivly).
Maybe instead of just shrinking the space bar, you could give shrinking those two a thought?
