google search
jab123
suggestions and corrects dont work on the search bar. will it be possible to incorporate this feature?
It's on purpose.. the android framework tells the keyboard if it has to enable suggestions or not. And in the case of a search, the keyboard is instructed to disable suggestions. Of course it could be overriden by an optional setting, if that's really needed
Jive
I would definitely like an option for text prediction/correction in all text boxes that Android says should not have it. This would make my decision between Smart Keyboard & Better Keyboard a lot easier (which currently has this option)...that and Voice input (i know you know we want that :))
Then I'll add it ;) that's quite easy
So, done in 1.3.2 (suggestions, not voice input ;) )
