So, starting from version 3.6.0 (you can already try the
beta) you will be able to install all the dictionaries (including English) to the SD card. Of course you will loose suggestions if you try to open the keyboard while the SD card is mounted, but hopefully it will not crash
This will also make the main app much smaller as the dictionary the biggest part of the package.
Can someone let me know the results?
