Problems with smart T9 Italian - htc legend 2.1
diabolikoo
This app is very cool but I have some problems, all with smart T9 layout:
  • there are no accented letters--> FIXED WITH VERSIONE 2.4.1 -->THANKS!!!;)
  • if I write a word and then do not put the space, the suggestions do not work anymore
  • It does not recognize a word and try to write a letter at a time, type the first letter and makes you choose between those on the key, then when you type the second does not give you more choice, and you remove the t9; same thing if you come back to deleting a word letter by letter -> gives only hints at the first touch of the first letter (in case of addition / deletion of one letter at a time, if you know what I mean ..)
  • if I write a letter and then put an apostrophe after the word takes me t9 until I leave a space, and same thing happens if you write a word then you just change the 'last letter does not give you more suggestions.
  • I can not set that when I enter eg 'e' this is selected as first choice.. always puts the 'd' letter because is the first, while the HTC keyboard was not so! and the same appens for the 'i', for 'o', for 'x' ...
  • in web browser (htc native) the predictions don't work!
  • Finally if you want to write individual letters with the t9 gives you tips only for the first, then you are forced to raise the t9
Sorry for my English, I'm Italian.
