Can't get Smart Key Pro to work on HTC Desire Z,maybe vision
Wolja
Installed Smart Key Trial. Worked well.
Bought smart key pro. Worked for a little . NOw I can't get any of them to work. Enable it in settings and get HTC keyboard.
Uninstalled reinstalled and restarted phone. No luck
I have a Desire Z so for sure there is no problem with this phone. Are you sure you changed the input method by doing a long press in a text field, then select "Input Method"?
