MIUI4 skin
tzarmo
Hello Awsome SKIN dude can u make it to work for my Wildfire S?
I try this zip but i think is made for higher resolution displays so if u can port it will be awesome!
Thanks you in advance
j23rh39hz3
I wanted a blue (highlight) version of this skin, so here it is in hdpi (high resolution).
Also, I recommend changing the text prediction color by going to Smart Keyboard Pro Settings -> Advanced Settings -> Candidate Color.
I set mine to #ff1962ce and it looks good.
MIUI4-blue.zip 18.3 KB · downloaded 1,114 times
