Its really nice to see some new skins showing up! Thanks If I could request another version with a slight tweak that would be great. The keys seem a bit too grey on my screen. It the key gradient could be brightened more white it would offer more contrast against the background. Again this might just be my phone (tbolt). Thanks again for something a bit new Goly
eddymjj
Thank you for your work.
Maybe a little wider keys as its look thin on WVGA
melaj88
Why does the skin come up black? i'm using an LG Optimus Slider with Gingerbread
aroykos
Took the liberty of creating a version with wider keys, using the above skin. Enjoy.
To the person who posted the wider version: could you please add a version in which the selection colour of the words in the prediction bar is a more neutral colour, like dark grey, instead of the standard screaming orange colour? thanks in advance!
aroykos
You can change this color in: Settings > Advanced settings > Candidate color SC20120610-235834.png
stevennekens
yeah, I kind of knew that. what I meant is not the colour of the font, but the colour of the background when you press it, the same colour that appears if you select a word from the prediction bar by pressing on it...
