Tap and slide to select individual letter
elesbb
Hello, i am not sure if i found this specific feature on this keyboard or on another ive tried.
But the feature is this, when using the COMPACT layout, i coulda swore that if you tap and hold on a key, for instance the GH key, it would allow you to tap and hold and slide to select either G H or 8. Is this a feature of SmartKeyboard pro or am i confused with another keyboard? But if this keyboard doesnt have this feature it really should add it :)
