[RESOLVED]Can't change skin?
danielson2047
Hello all! Been using SKP for over 2 years now without a hiccup. I installed it right away on my Galaxy Nexus LTE when i got it and it ran without issue until now. I have many custom skins, and all of a sudden i cannot select them. My skins folder is there on my sd card, where its always been, but when i go to change the skin i only have the 5-6 default skins. I discovered this when flashing a new rom, so i went back to my backup and my skin is still the custom skin i had, but if i go to change it its the same thing, just the default skins. Any ideas?
danielson2047
Solved my own problem. Just as a "why not" i looked and noticed my "skins" folder had a capital "s", i changed it to "skins" and voila, all my skins appeared. Its been spelled with a capital S as long as i've had it, and worked fine on my Droid 1 and my T-Bolt. Not sure why all of a sudden it stopped working, latest update possibly?
