Force Close
_Vovka_
Hi.
After upgrading to "TALHO ROM v5.0X Gamer Edition для LG P500" i received fc of SK (pro 4.6.1)
Tried:
ROM Manager-> fix permisions
moved app and langs to RAM, ROM, SD (and reboot, reboot, reboot ...)
wipe data (in app property and via titanium backup)
enable-disable in system keyboard settings
Android device log:
Log Collector version: 1.1.0
Device model: LG-P500
Firmware version: 2.3.7
Kernel version: 2.6.35.13-XIII+
roq@mioptimusone[dot]com )
#11 PREEMPT Sat Apr 14 17:31:49 PET 2012
Build number: VERSION 4.8X+
On 2.2.1 SK run perfectly (in ROM)
How can i force SM not to force close?
Try clearing application data in Settings>Applications>Manage Applications.
_Vovka_
TheTehk17 wrote:Try clearing application data in Settings>Applications>Manage Applications.
i did it in first try: wipe data (in app property and via titanium backup)
may be this is because TALHO ROM (CM7 custom) but ...
"Android keyboard" and "Perfect keyboard" work well so i switch to AK (features are the same)
Try uninstallling and reinstalling SKP from the Market.
If that does not work contact the ROM developer and explain the issue.
