hello dev! I was so surprised and loved the korean support, and I have never expect this keyboard would bring me korean input! and it is only korean keyboard that does auto-correct in the market!
However, as you know, it does not have a dictionary yet, so i added some korean words on user dictionary - and i used this awesome auto correct then i found a bug - or an error with auto correct.
so here's deal - i will show some example by showing korean character -
i added few words on my user dictionary - such as 사랑해 - which means i love you -
so even thou i made mistake like 사란해 - then press space - it will automatically turn into 사랑해
but here's the thing. - when i hit back-space again from that - it will go back to 사란해 - and shows me other suggestion, right? but not only that - it erases other characters in the back - as this word 사란해 has three character, it erases 3 characters in the back.
1. i type with some typo -
-> i love you in korean is 사란해
2 then i press space then it will autocorrect to 사랑해
-> i love you in korean is 사랑해
3 however if i press backspace immeidately - it will goes back to 사란해 with erasing some characters before the word
-> i love you in korean 사란해
this is how it happens. so some ppl can say its little minor issue - but when it comes to korean - three characters could hold many meanings...
hope this diagram helps so you could work on the problem
and will korean dictionary be provided, soon?
