I changed my phone from Droid1 to samsung galaxy nexus with android 4.0. When I re-downloaded smart keyboard pro it is selected in the settings, but I can't activate it. When I long press in a text box I get no input choice and the phone just keeps using the Android keyboard even though it is deselected in Settings. Can you help me?
can't activate
Hi matey...I had this problem after resetting my Galaxy S2...after installing the disastrous Ice Crap Sandwich.
the long press doesnt work on the later versions. I accidentally found this. On the standard keyboard skin, there is a settings icon...a little gear wheel....you might have to swipe left or right to enable it. Hold this for a bit and the menu to choose Smart Keyboard comes up.
Bob
Bob
